Register Photo Gallery FAQ Members List Calendar Search Today's Posts Mark Forums Read
Welcome to Stuntlife !
Welcome to Stunt Life,
Old 09-18-2008, 11:17 PM   #21
MiNi GuineA
-Damage Control Products-
MiNi GuineA's Avatar
Bike: HoHey'd OuT F4i!!
Gender: Male
MiNi GuineA is a decent person
Re: Stunt bike build (for noobs)
Nice!
MiNi GuineA is offline   Reply With Quote
Sponsored Links
Old 09-19-2008, 01:46 PM   #22
cbrstuntz
IMR
Bike: 1993 cbr 900 rr
Gender: Male
cbrstuntz is a decent person
This must be sticky!!!
cbrstuntz is offline   Reply With Quote
Old 09-19-2008, 02:02 PM   #23
50slut
"King of Braaaap"
50slut's Avatar
Location: deep dirty south Illinois you fucks not missouri
Bike: a few F4i's HoHey'd out and a CRF50slutted out
Gender: Male
Honda F4i and 600RR idle mod. & clean air mod a MUST just do it dont ask why, i dont feel like explaining now i will do so later!
Idle Mod.
Clean Air Mod.
50slut is offline   Reply With Quote
Old 09-19-2008, 02:03 PM   #24
50slut
"King of Braaaap"
50slut's Avatar
Gender: Male
Talking Re: Stunt bike build (for noobs)
Nags wut up on the sticky????
Old 09-19-2008, 02:11 PM   #25
cassman
cassman's Avatar
Bike: 07 gixer 1000, 08 custom (my first build), 03 warrior got fuckin stolen...bastards...
Gender: Male
cassman is a decent person
great explanation and info Juca and 50slut, that should help alot of people from busting their asses....
cassman is offline   Reply With Quote
Old 09-19-2008, 02:14 PM   #26
Juca
King of brake lines
Juca's Avatar
Bike: Cbr F2 and Apn 6
Gender: Male
Juca has a brilliant future Juca has a brilliant future Juca has a brilliant future Juca has a brilliant future Juca has a brilliant future Juca has a brilliant future Juca has a brilliant future Juca has a brilliant future Juca has a brilliant future Juca has a brilliant future Juca has a brilliant future
Send a message via MSN to Juca
good job 50slut!
Juca is offline   Reply With Quote
Old 09-19-2008, 02:19 PM   #27
50slut
"King of Braaaap"
50slut's Avatar
Gender: Male
Originally Posted by Juca View Post
good job 50slut!
Thanks im sure i'll think of sum more stuff while im riding today to add later :YEAH
Old 09-19-2008, 02:58 PM   #28
cassman
cassman's Avatar
Gender: Male
damn work, wish i could get out and ride all day....
Old 09-19-2008, 09:43 PM   #29
Juca
King of brake lines
Juca's Avatar
Gender: Male
F4i ACERBIS HEADLIGHTS WIRING (ACERBIS CYCLOPE)
LOW BEAM AND RUNNING LIGHT :
HIGH BEAM :
Ok heres what i did to hook mine up... figured id post a little how to... just becase.
You will end up with the lowbeam and running light on at the same time, and the highbeam still running off of your highbeam switch.
Alright First i took the Acerbis headlight spliced the grounds (both black) together so the 2 wires run into 1 wire for the lowbeam and the running light.
Then i took the Acerbis headlight and spliced the positives (1 white 1 red) together from the lowbeam and running light.
With that i ran them into the 3 slot connector (only using 2 slots) supplied with the Acerbis headlight.
Finally i took the 2 wires for the High beam (1 black (-), 1 white (+)) and just ran them into the 2 slot connector supplied with the Acerbis Headlight.
Now for the headlight Harness
First thing i did was clip off the stock headlight Connectors
Then I replaced the the Stock Headlight Connectors with the new ones Supplied with the Acerbis Headlight.
Low beam should be (green (-), Striped blue (+) )
High beam should be (green (-), Solid blue (+) )
Now for the tip over sensor.
You can either take it off of your stock headlight and remount it on the bike somewhere.
Or you could do what i did make a jumper out of just a piece of 14g wire i got at autozone. Then take the jumper and put it from the red to green wire inside of the connector and just tape it to the harness.
you can also clip off the Connector twist the red and green together and tape off the white all by itself. Either way you will have to do something with being the bike will not start without it.
THANKS Nine54f4i FOR THIS POST !
Old 09-19-2008, 10:31 PM   #30
Juca
King of brake lines
Juca's Avatar
Gender: Male
ACERBIS HEADLIGHTS :
Blitz :
Forge new trails with the revolutionary Blitz headlight! Incredible design, functionality and aerodynamics fused by Acerbis’ R&D department equate to a product without compromise.
• Stacked headlight design in state of art
• Dual 35W halogen lamps for great illumination
• Central heat-resistant unit accepts bulbs up to 50W
• 10° Pencil and 38° Flood
•Will fit virtually any motorcycle
Availble in:
CR Red, YZ Blue, Black, Green, KTM Orange and Yellow.
DHH :
Dual 12 volt, 35 watt, tungsten halogen bulbs
50mm diameter glass lenses with high-gloss reflectors
Pencil beam directs the light straight out with a 10° arc
Flood beam directs the light closer to the bike over a 38° arc
Diamond :
The Acerbis Diamond headlight represents a revolution in headlight design. The Diamond was the first headlight to include two halogen bulbs in an aftermarket headlight and now it has three! The Diamond is equipped with polycarbonate lenses and a polypropylene number plate above the headlight. This headlight can be adapted to fit a wide range of dirt bikes and some street bikes.
• Mounts with two plastic brackets and four rubber straps
• Fits virtually any motorcycle
• Two center bulbs are 36° floods and the third bulb is the 10° pencil, giving a broad field of illumination.
Cyclope :
Nylon surround
Polypropylene nuberplate
Polycarbonate reflector
Cast aluminium headlight body and tempered glass lens.
TUV certified. DOT,ECE and SAE approved.
Ajustable angle.
Universal fitting with anti-vibration rubber strips.
Removable number plate
Available in a wide variety of colours.Protective, transparent polycarbonate lens cover supplied for off -road use.Heat resistant plastic headlight support.Wiring accessories provided.lLow beam fitted with 55w halogen bulb, low beam /side light fitted with 55w halogen bulb and 5w incandescent bulb.
Old 09-20-2008, 05:00 AM   #31
50slut
"King of Braaaap"
50slut's Avatar
Gender: Male
[color=lime]
sorry Juca not hattin i just dont recomend doin either of these, due to the fact that if you relocate it its still functional and can still shut off mid wheelie and if you do the jumper it can get jared or lossen up and come out also causing bike to shut off mid wheelie
the way i like to do it is either cut the 3 wires red,white n green 1 AT A TIME otherwise you'll blow a fuse if you cut all three at once, then connect the red n green together i use 3M ScotchLoks they are the shit and thats it never have to worry bout it again
Old 09-20-2008, 05:21 AM   #32
Juca
King of brake lines
Juca's Avatar
Gender: Male
50slut thanks becouse you correct me cya boys time to ride yeeeeeea
Old 09-24-2008, 02:10 PM   #33
Thasick1
Thasick1's Avatar
Bike: 95 ex500 stunter, 86 FZ750, 89 zx750
Gender: Male
Thasick1 is a decent person
bump this
Thasick1 is offline   Reply With Quote
Old 09-24-2008, 09:06 PM   #34
Juca
King of brake lines
Juca's Avatar
Gender: Male
Originally Posted by Thasick1 View Post
bump this
Thanks for bumping!
Old 09-25-2008, 02:35 AM   #35
cruzer636
cruzer636's Avatar
Bike: 03 636 loong gone! an 06 CBR 1000, 06 Gsx-r 750, Honda cr 250 2stroke
Gender: Male
cruzer636 is a decent person
Nice!!!
cruzer636 is offline   Reply With Quote
Old 09-25-2008, 06:46 PM   #36
Juca
King of brake lines
Juca's Avatar
Gender: Male
Who can make this sticky? I hate bump it whole time...
Old 09-28-2008, 01:42 PM   #37
Thasick1
Thasick1's Avatar
Gender: Male
I can make it sticky, but not A sticky
Old 09-28-2008, 01:52 PM   #38
Juca
King of brake lines
Juca's Avatar
Gender: Male
wft ??
Old 10-02-2008, 11:44 AM   #39
Juca
King of brake lines
Juca's Avatar
Gender: Male
bump.
Old 10-05-2008, 05:01 PM   #40
fReEsTyLePiMp
fReEsTyLePiMp's Avatar
Bike: wtb: f4i
Gender: Male
fReEsTyLePiMp is a decent person
I like this thread, what kind of headlights do the streetfighterz use ?
fReEsTyLePiMp is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
SEO by vBSEO 3.0.0 RC6
