User Name
Password
Old 02-14-2008, 12:45 AM   #41
nags
FUCK IT.
Bike: 2003 F4i / 2002 Honda CBR954 / Yamaha Zuma
Gender: Male
Re: CBR1000RR Throttle tube/cables on F4i
Well the kill switch is seperate from the throttle so it's not big deal if that spins.
The only pain was the friggin' throttle cables for me. I gave up and went with the f4i since I didnt need the added length.
__________________
Advertise Here!
http://www.the-nags.com/
http://www.stuntex.com
http://www.moto-heaven.com
nags is offline   Reply With Quote
Old 02-14-2008, 12:59 AM   #42
50slut
HONDA user
50slut's Avatar
Bike: F4i HoHey'd out
Gender: Male
50slut is a decent person
the 1000rr throttle/ kill start button i have is off an 07 so wut kinda pain am i gonna have when i try to rewire the kill start setup????
50slut is offline   Reply With Quote
Old 02-14-2008, 01:02 AM   #43
nags
FUCK IT.
Gender: Male
Well it'll either be like mine where you're left with 2 wires that don't match or they'll all match up. No big deal eiter way.
__________________
Advertise Here!
Old 02-14-2008, 01:07 AM   #44
50slut
HONDA user
50slut's Avatar
Gender: Male
cool so no sweat there, did you solder then shrink wrap everything??
Old 02-14-2008, 01:09 AM   #45
nags
FUCK IT.
Gender: Male
Was going to heat shrink it but didn't have any here small enough so I just went for the ghetto electrical tape method
__________________
Advertise Here!
Old 02-14-2008, 01:14 AM   #46
50slut
HONDA user
50slut's Avatar
Gender: Male
ok so i'll make sure to have sum shrink wrap thanks
Old 02-14-2008, 01:18 AM   #47
nags
FUCK IT.
Gender: Male
Make sure you get some real small stuff
__________________
Advertise Here!
Old 02-14-2008, 01:21 AM   #48
kj
kj's Avatar
Bike: 05 f4i
Gender: Male
Originally Posted by 50slut View Post
i i got db bars so the extra 1.5" on the 1000rr cables will help...
I used f4i cables, and once they're turned down and under it gives you a good amount of extra room to work with... so try it w/ your f4i cables 1st.
And the ghetto electrical tape method? Is there any other way?
kj is offline   Reply With Quote
Old 02-14-2008, 01:32 AM   #49
50slut
HONDA user
50slut's Avatar
Gender: Male
fosho, i got tons of shrink wrap all diff sizes so i be good there and my stock F4i cables are long enought but when i turn my shit almost all the way to the right the rpm's go up a bit so i figured the extra 1.5" would help but i'll try with the stock ones 1st since nags had all the more headache than i wunt with the cables
Old 02-14-2008, 01:35 AM   #50
Towlieee
Towlieee's Avatar
Bike: 02F4i 05Fiddy 05Crf150
Gender: Male
Towlieee is a jewel in the roughTowlieee is a jewel in the roughTowlieee is a jewel in the rough
ya whats this heat shrink shit everyone talks about
So you can 1000rr setup with f4i cables?
Just curious, whats really the difference then with the 1000rr setup vs f4i? Coudln't I just drill the hole on top of my bars, and flip the f4i setup upside down and be the same as a 1000rr setup? IE coming out the bottom?
I got db bars, and would like a LITTLE more reach, but don't need much.. I've been riding fine wiht a stock setup forever, but when my bars cranked, my throttle gets a little touchy lol
Towlieee is offline   Reply With Quote
Old 02-14-2008, 01:45 AM   #51
eazenutz33
Bike: ............
Gender: Male
you can reroute your throttle cables and shit outside of the fork tubes and that problem will go away as long as you dont kick the cables with some weird uncool combo or somin. Did that on my RR when I had DB bars on it still and ha d the same problem.
The 1000RR throttle housing is alot more adjustible without having to move the kill switch.
Also, I dont have the nipple on the 1000RR housing at all and it tightened down really tight without any issues so far....and I've dumped it hard a couple times with it. Made setting my lever space for my gix radial much easier with the 1000RR housing.
eazenutz33 is offline   Reply With Quote
Old 02-14-2008, 01:52 AM   #52
50slut
HONDA user
50slut's Avatar
Gender: Male
my cables are outside the fork tube and the rpm's still go up when turned to the right how do you have yours mounted is kill switch facing up or towards the front???? mine is facing up!
Old 02-14-2008, 01:57 AM   #53
eazenutz33
Bike: ............
Gender: Male
mine was on my RR...may have been slightly longer, but I thought it was shorter. I would have my cables pointing as straight down as possible, then you can also turn the metal angles on the housing to face the bike a 1/4"-1/2" and will give you a cunt hair more.......I just kept playing with it until I had it perfect, then I came to my senses and got Vortex clipons!
Old 02-14-2008, 02:01 AM   #54
kj
kj's Avatar
Bike: 05 f4i
Gender: Male
Yea ya could... and i tried it once but the starter button would be facing forward on the top. Know what I mean?
Yea.. and as I said above... it's more the starter button than the kill switch... I actually have my kill switch dis-abled at the plug cause I NEVER use it, nor do I EVER want to.
But sometimes after a stall i wanna start up quick... like before the tire even touches the ground. And not havin that starter button right there would fuck me up bigtime.
I think it's really worth the 1krr swap... just that lil extra bit you get from the cables being on the bottom helps w/ that lil bit of throttle pull your getting.... I used to have the same thing.
Old 02-14-2008, 02:12 AM   #55
50slut
HONDA user
50slut's Avatar
Gender: Male
kj how did you disable the kill switch, just take the 2 wires that go to it inside the housing and solder em together???? shit i never use mine either i ALWAYS use the key
Old 02-14-2008, 02:16 AM   #56
kj
kj's Avatar
Bike: 05 f4i
Gender: Male
yea but down below the plug(on the bike side)... just cut the 2 wires (can't remember colors right now).. but cut em and splice em together REAL TIGHT!!
For that one I used one of those small plastic crimp caps.
Old 02-14-2008, 02:18 AM   #57
50slut
HONDA user
50slut's Avatar
Gender: Male
cool im on it
Old 02-14-2008, 03:26 AM   #58
*Tanus*
*Tanus*'s Avatar
Bike: xr72,f4
Gender: Male
*Tanus* is a decent person
l
the 1000rr unit is metal and smaller, and it looks pimp
*Tanus* is offline   Reply With Quote
Old 02-14-2008, 11:49 AM   #59
eazenutz33
Bike: ............
Gender: Male
yeah with the 1000RR setup you can mount the throttle cables at any angle....and have the kill switch facing like stock, turned up where the starter button points straight up, straight down, whatever you want.....thats why I like the setup better. I need to get my hands on a 1000RR kill switch. I actually did use it a lil shutting the motor off in coasters, then starting again after 4-500' before setting it down. Anymore I just turn the idle way down....roughly the same sound.
I think we're sayin the same shit, just in diff. phrases
Old 02-14-2008, 12:00 PM   #60
nags
FUCK IT.
Gender: Male
Yep
__________________
Advertise Here!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
SEO by vBSEO 3.0.0 RC6
