User Name
Password
Old 05-01-2004, 12:05 PM   #1
JJmX84
JJmX84's Avatar
Bike: CRF250, CRF450, XR50
Gender: Male
JJmX84 is an unknown quantity at this point
Unhappy Aftermarket brake pedal - need help installing
Okay, so I just got a Reeg Racing billet rear brake lever (same as Two Bros) in today and I'm having a lot of trouble getting the brakes to work now. I put it on, and for those of you who have put one on know, the hole on the brake lever in which the rod to the drum brakes goes into, is a little farther forward. I pulled the lever (connected to the rod) off of the drum brakes and moved it up so I could get the rod to reach. Now that it does, I can't get the rear brake to work right. When I get it all put together the rear brake drags big time. I tried adjusting the nut on the back to loosen it up, but it doesn't loosen enough, it still drags. I tried re-adjusting the lever about 20 times and still couldn't get it to work. The only way I could get the brakes to work was if the wheel was all the way forward in the swingarm, then I couldn't tighten the chain. Has anyone else run into this problem? If so, could you help me out and let me know the trick. Thanks.
J.J.
JJmX84 is offline   Reply With Quote
Sponsored Links
Old 05-01-2004, 01:42 PM   #2
FIVEO
FIVEO's Avatar
Bike: 2003 xr50 2002 pw50 2002 yz250 2004 drz 110
Gender: Male
FIVEO is a decent person
Re: Aftermarket brake pedal - need help installing
look at where the brake lever is under the right foot peg... it should be just under the pivot point...maybe your lever is bent out and is already applying prssure???? just athought
__________________
Thank You Crack Heads for the job security.........Keep sucking the glass D--}
FIVEO is offline   Reply With Quote
Old 05-01-2004, 02:05 PM   #3
Xidium
Xidium's Avatar
Bike: 2002 kx125 97' z50 03' xr100 76 xr75
Gender: Male
Cut some links off your chain then. Keep in mind they come 2 at a time.
__________________
[img]http://www.danasoft.com/vipersig.jpg[/img]
Xidium is offline   Reply With Quote
Old 05-03-2004, 02:34 AM   #4
JJmX84
JJmX84's Avatar
Gender: Male
FIVEO...the pivot point is under the pedal. The brake pedal is straight. The reason the brake would drag is because of having the rod pulled up so far to connect it to the brake pedal it would be pulling on the brake arm, in turn dragging the brakes.
Xidium...The only problem w/ that would be that I still won't be able to tighten my chain in the future when it gets tight because I won't be able to pull the wheel back at all.
Thanks for the suggestions, though.
Does anyone know if any companies make an extended brake rod to connect to the brake pedal? That's the only thing I can think of that could solve the problem.
Old 05-03-2004, 12:56 PM   #5
RYANCRF50
RYANCRF50's Avatar
Bike: CRF50
Gender: Male
RYANCRF50 is an unknown quantity at this point
You should call REEG...(916) 933-7090 I'm sure XR STUNNA (Steve) or Kim Reeg would help you, and take care of the problem.....they are really cool guys and they take care of their customers! Or at least go to their website www.crf50s.com and email them.
RYANCRF50 is offline   Reply With Quote
Old 05-07-2004, 06:59 PM   #6
Z50NATIONALS
Z50NATIONALS's Avatar
Bike: ZRX100 ,03 XR50,72 YAMAHA R5
Gender: Male
i don know the pedal is it ising the stk rod?
Z50NATIONALS is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
F2 F3 rear brake pedal MikeM Parts: Wanted 0 11-17-2003 05:10 PM
Rear brake pedal KOTO XR50 & Minibike Forums 15 10-17-2003 11:14 PM
wanted 929 brake pedal -Si Parts: Wanted 1 08-02-2003 02:07 AM
rear brake pedal mods? grampa XR50 & Minibike Forums 7 07-25-2003 01:15 AM
929 brake pedal and damper itsmegb Parts: Wanted 0 05-30-2003 11:03 AM
SEO by vBSEO 3.0.0 RC6
