| | Thread Tools |
| | #1 |
| Registered User ![]() Join Date: Jul 2003 Location: Wells, Maine Age: 24 Bike: 2003 GSXR 600, 2003 XR50 Gender: Male
![]() | kickstarter oil seal problems the kickstarter oil seal is blowing out on me, when i open the oil cap it releases pressure do anyof you guys know what could be causing this? |
| Sponsored Links | ||
| | #2 |
| Registered User ![]() Join Date: Mar 2004 Location: dallas,tx Age: 39 Bike: fiddys Gender: Male
![]() | Re: kickstand oil seal problems check on the back of the motor and make sure your crankcase hose isnt pinched or clogged your kickstand seal? shifter seal? countershaft seal? could just be worn out too |
| | #3 |
| Registered User ![]() Join Date: Jun 2003 Location: kewaunne wi Age: Bike: 2002 kx125 97' z50 03' xr100 76 xr75 Gender: Male
![]() | Re: kickstand oil seal problems If you open the dipstick wile the motor is running its going to shoot out.
__________________ [img]http://www.danasoft.com/vipersig.jpg[/img] |
| | #4 |
| Registered User ![]() Join Date: Feb 2003 Location: Del Rio, TX Age: 27 Bike: F4i/fiddie Gender: Male
![]() | Re: kickstand oil seal problems I had the same problem. At the back of the motor, in a tight little space between the tire and the motor, there is a little hose that comes out, it almost looks like a wire. follow it, and if it goes to the left side of the bike that is the one. The hose will go to a little black box on the left side of the bike tucked in almost under the seat, then there is another hose that comes out of that little black box, it goes to a another little box with a dome on one end. Check all of these hoses to see if they are pinched. That should be Your problem |
| | #5 |
| Registered User ![]() Join Date: Jun 2003 Location: St. Louis Age: 23 Bike: Too many to list Gender: Male
![]() | Re: kickstand oil seal problems I know when I installed my 88cc kit, it was doing the same thing. I bought a bigger oil pump and breather tube you put on the head and now it works great. But if you put too much oil or the tube is pinched it'll shoot oil out of the tube from the head.
__________________ I Loooove Animals! This tastes like grandma! |
| | #6 | |
| I Enjoy Posting At StuntLife! ![]() Join Date: Aug 2003 Location: Chicago, Illinois Age: 31 Bike: Z50R & TRX90 Gender: Male
![]() | Re: kickstand oil seal problems Quote:
What will shoot out oil or air? Oil won't shoot out of mine with the dipstick out and engine running.
__________________ "Its Tough Being a STUNTLIFE Superhero" www.chicagoriders.com | |
| | #7 |
![]() | Re: kickstand oil seal problems Oil, that means you dont have enough in there then. Because the gears are moving the oil will fly around. I did that once, got covered.
| | #8 |
| I Enjoy Posting At StuntLife! ![]() Join Date: Jul 2003 Location: nova/dc Age: 26 Bike: CBRF4i(rip)/CRF50/DKbmx Gender: Male
![]() | Re: kickstand oil seal problems i've never seen a fiddy spew out oil from the dipstick hole unless it had a pinched hose. you should be able to take it off when it's running no prob. B |
| | #9 |
![]() | Re: kickstand oil seal problems i use an old 70 motor no c/c vent, seeps a minimal amount of oil around the kickstarter and oil fill cap,no puddles, i just wipe it off if its more than that then you need to fix it ive never started one up(50) with the dipstick off so i dont know but generally it will spew oil out because normally its beside the clutch hub which in alot of cases the lower part is emersed in oil and it would seem to me a 50 would be no different, isnt that why there is an o'ring there on the dipstick?if you take the oring off it will leak oil there.... |
| Thread Tools | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| 929 problems | Ryno | Stunt Discussion | 14 | 06-29-2004 01:56 AM |
| f4i 2nd gear problems | famtrecrew | Service, Repair, and Maintenance | 4 | 12-06-2003 01:56 AM |
| Stunt Damage | bikerboy | General Sportbike Discussion | 25 | 10-25-2003 11:17 PM |
| Ques 4 biker boy | metric2000 | General Sportbike Discussion | 11 | 10-25-2003 02:32 PM |
| Did I blow a seal? Fork seal that is | ftrain | Core6 | 12 | 05-07-2003 03:04 AM |
