User Name
Password
Old 04-03-2004, 01:50 PM   #1
needa50
needa50's Avatar
Bike: 2004 CRF50 k&N filter, 88cc big bore, 15t sprocket more mods on the way, Rm125
Gender: Male
needa50 is an unknown quantity at this point
Help My Fiddy!!!!!
for some reason, last night my fiddy started like ****in up. It is okay when i am half throttle, but when i pull it all the way when ur riding, it like has little spurts of drag, so it cant get going very fast. When it is doing this, the muffler like has those little shots of sound, except louder and more abnormal. Its really hard to explain...I cant get into the dealership till monday! Please help me so i can start !
needa50 is offline   Reply With Quote
Sponsored Links
Old 04-03-2004, 03:31 PM   #2
50Pilot
Bike: xr50,2 z50, sv650, wbII
Gender: Male
50Pilot is an unknown quantity at this point
Re: Help My Fiddy!!!!!
Clean the carb. Take it off. Open up the float. Dump out the crud. Take out the jet and clean it. Take out the funny looking brass peice under the jet and clean that too; this is where you will find some stuff plugging up everything. Take the mixture and idle screw out counting the amount of turns it took to do so. Clean out the body of the carb with some carb cleaner. Don't do it over the sink where little things can fall out. What I usually do and have never had a problem is take out all rubber and plastic peices and put it in a pan with some water and boil it. Dry it off, get all the water out and put it back together. Should not take that long and is not very difficult.
Get a $2 fuel filter.
50Pilot is offline   Reply With Quote
Old 04-03-2004, 04:39 PM   #3
mekrew
Bike: 01 xr50 - 06 636
Gender: Male
mekrew is an unknown quantity at this point
make sure bike is grounded friend had same prob and we found out when we painted frame that we didnt grind the paint off where we ground the bike
mekrew is online now   Reply With Quote
Old 04-03-2004, 05:02 PM   #4
potential
potential's Avatar
Bike: CBRF4i(rip)/CRF50/DKbmx
Gender: Male
potential is a decent person
good advise...
B
potential is offline   Reply With Quote
Old 04-03-2004, 08:58 PM   #5
needa50
needa50's Avatar
Gender: Male
shit, i think it is the grounding, cuz i was ****in wit the 'lectrical shit, and i dont think its the carb, cuz its 3 weeks old outta tha shop
Old 04-03-2004, 09:13 PM   #6
needa50
needa50's Avatar
Gender: Male
thanks alot, problem solved! the wire to ground the bike was loose on the screw, and when the bike vibrated it didnt always connect so the engine was pissed
Old 04-04-2004, 12:13 AM   #7
potential
potential's Avatar
Gender: Male
damn right i knew that was it... good lookin out mekrew.
B
Old 04-09-2004, 12:45 AM   #8
mxrider131
Bike: 2001 yz250
Gender: Male
mxrider131 is an unknown quantity at this point
mt bike is doing the same thing. Its fine all the way until top end then it pops and bogs. My ground screew is tight and I also just cleaned the carb. what else could it be?
mxrider131 is offline   Reply With Quote
Old 05-04-2004, 11:19 AM   #9
Kawkidd
Kawkidd's Avatar
Bike: 93 ZX7R 75 Kz 04 CRF Fiddy
Gender: Male
Kawkidd is an unknown quantity at this point
Is this bike all stock? If so see also REV-LIMITER...
__________________
...9 out 10 voices in my head say,[COLOR=Red]"Pull the trigger"[/COLOR]...
Kawkidd is offline   Reply With Quote
Old 05-05-2004, 07:40 PM   #10
Z50NATIONALS
Z50NATIONALS's Avatar
Bike: ZRX100 ,03 XR50,72 YAMAHA R5
Gender: Male
also you might check the wires on the coil and make sure they are snug on there
that will make it miss fire at top end from the vibration of the motor
mine did it the other day kid crashed and it ran like chit took a minute to find it
Z50NATIONALS is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
lookin for a fiddy LILSTUNTER03 XR50 & Minibike Forums 8 03-08-2004 01:16 PM
Took my fiddy to the MX track! GixxerPete XR50 & Minibike Forums 7 08-18-2003 12:08 PM
me buy fiddy Brian_C6 Core6 15 06-18-2003 12:00 PM
me buy fiddy Brian_C6 Reckless Methods 0 06-17-2003 04:29 PM
Mistaken Identity - Another fiddy fugitive gets away Dax XR50 & Minibike Forums 1 06-04-2003 12:34 AM
SEO by vBSEO 3.0.0 RC6
