User Name
Password
Old 12-07-2007, 05:00 PM   #1
iker
Bike: klx 250 s crf50
Gender: Male
iker is a decent person
wont stay running
I let my fiddy sit for a couple of months now it will only stay running with the choke on.I drained the gas and put fresh gas still the same.Any ideas
Thanks
iker is offline   Reply With Quote
Sponsored Links
Old 12-07-2007, 06:22 PM   #2
DSC
DSC's Avatar
Bike: minty 05 CBR1000RR, 04 f4i , 06 450r, and a fiddy
Gender: Male
Re: wont stay running
check for spark, then see if plug is wet
__________________
www.powerstuntworxs.com
www.fullthrottleinc.net
www.haibikeshop.com
www.trianglecycles.com
www.hoheydesigns.com
DSC is offline   Reply With Quote
Old 12-07-2007, 06:24 PM   #3
DSC
DSC's Avatar
Gender: Male
if sparks and dry= check fuel, if sparks and wet= check air, if no spark = check cdi box
__________________
www.haibikeshop.com
Old 12-07-2007, 07:31 PM   #4
iker
Gender: Male
It'l run forever as long as long as the choke is about 3/4 on as soon as I start to turn the choke off it dies. The plug looks fine.I also cleaned the air filter. I'm thinking mabe the float is stuck.
Old 12-11-2007, 02:13 AM   #5
tmereider
Bike: 06 f4i and yfz 450
Gender: Male
tmereider is a decent person
my fiddy got a problem with runnin will run with the choke on when you turn the throttle it boggs down shut the choke of it dies put on a new carb same thing
tmereider is offline   Reply With Quote
Old 12-11-2007, 04:23 AM   #6
xxMICKEYxx
xxMICKEYxx's Avatar
Bike: F4i,929
Gender: Male
xxMICKEYxx is just really nicexxMICKEYxx is just really nicexxMICKEYxx is just really nicexxMICKEYxx is just really nice
your pilot jet is clogged up
xxMICKEYxx is offline   Reply With Quote
Old 12-11-2007, 07:32 PM   #7
tmereider
Gender: Male
yea but bought new carb does same thing took apart and cleaned
Old 12-11-2007, 09:29 PM   #8
xxMICKEYxx
xxMICKEYxx's Avatar
Bike: F4i,929
Gender: Male
well next time be more specific! did the carb come with all new jets? if so are they they the right ones? did u set the idle? did u adjust the pilot screw?
Old 12-13-2007, 01:21 AM   #9
custom07exhaust
custom07exhaust's Avatar
Bike: 2007 gixxer
Gender: Male
custom07exhaust is a decent person
if its running that means its got compression and spark....its the a/f mixture....adjust the needles on ur carbs...
__________________
pissing you off and making your kids smile
custom07exhaust is offline   Reply With Quote
Old 12-19-2007, 02:22 PM   #10
supersquid750
supersquid750's Avatar
Bike: 02 gsxr 750 and pit bike
Gender: Male
supersquid750 is a decent person
i have the exact same problem and i would like to know how to clean a carb cause this would be my first time and is it easy or hard?
supersquid750 is offline   Reply With Quote
Old 12-19-2007, 07:14 PM   #11
custom07exhaust
Bike: 2007 gixxer
Gender: Male
air tank...hook up air chuck with trigger...stick it in the hole of the carb weer the gas line runs to open the float and blast away the air it will clear the path were ever the gas is running through
__________________
Old 12-22-2007, 09:20 PM   #12
hughes_097
hughes_097's Avatar
Bike: a wheelie monster
Gender: Male
hughes_097 is a decent person
my did the same thing i said fuck it just started revving the piss out of it holding it whide open for 30 seconds back firing sputtering and than it just died than i started it back up and ran fine :YEAH sick lol idk just what i did
hughes_097 is online now   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
SEO by vBSEO 3.0.0 RC6
