SOLID ALUMINUM FORK STIFFENERS Anyone running them???
Old Jul 27, 2007 | 09:53 AM
huntersirg is an unknown quantity at this point
Hey I just picked up a fiddy and it needs the suspension beefed up. Im doing the cheap route with just a rear spring, diy rear shock spacer(?), And Im definently doing heavy duty fork springs and the bushings up front. I saw these on ebay, these forks seem like they are prone to bend (stoppies anyone?). Has anyone seen these befor, used or using them? I think the only con to these would be altittle added weight to the front. think their worth it, 20 bucks isn't bad if it saves you from buying new forks.
http://cgi.ebay.com/ebaymotors/SOLID...mZ110147454886
Old Jul 28, 2007 | 12:28 PM
Ryan Moore's Avatar
Ryan Moore is an unknown quantity at this point
Re: SOLID ALUMINUM FORK STIFFENERS Anyone running them???
I used to make them and they seemed to work good, the only problem is that the actual dropout were the axle goes throgh the fork, would still bend and my tire would constantly rub the for leg and not roll. Chromo legs are the way to go, but those might get you by for a little while.
joeybaila
Nov 9, 2020 05:52 AM
WickedJ
Jul 26, 2013 02:58 AM
DeadlyInstincts
Jun 23, 2013 06:23 PM
zeus_r6
Apr 2, 2013 04:26 PM
kawasaki622
Dec 4, 2012 10:31 PM
