| | Thread Tools |
| | #1 |
| Registered User ![]() Join Date: Apr 2003 Location: Home Age: 28 Bike: 03XR50 Gender: Male
![]() | nOOb Question! whats up fellow fiddy riders! i'm new here and plane to stay for a long time! the site is great! One Question: how can i make the rear brake on my fiddy into a hand brake;without buying those over priced ones? if someone could give me detailed instructions, i would really appreciate it!!!!!!! thanks so much!!!!!!! Thanks and glade to be here! ![]() |
| Sponsored Links | ||
| | #2 |
| Regular StuntLifer ![]() Join Date: Oct 2002 Location: columbus , ohio Age: 36 Bike: 98 GIXXER 02 XR50R Gender:
![]() | Depends on how good you are at fabricating things. I made my own out of BMX brake leftovers. It wont lock up the rear tire like the foot brake will but it will help you balance out the wheelies. I am at work so I cant post pics but I can give you the run down. Use a BMX brake lever and run the cable back to the right side of the engine block. Fabricate an L bracket that will mount to one of the engine case bolts. Mount the long side of the L to the engine and on the short side mount a BMX brake tension adjuster . Then run the cable to the rear brake lever and drill a hole and use a BMX brake cable clamp style nut and bolt to crimp it tight . Now you have a rear brake on the bars for around 15 bucks. later , mike |
| | #3 | |
![]() | Quote:
is there any way i could get the brake to be as good as the foot brake? if you could, post some pics when you get home! Thanks!!!!!!!! ![]() | |
| | #4 |
![]() | ttt ![]() |
| | #5 |
![]() | Not a very good pic but ...... |
| | #6 |
![]() | another shot....... |
| | #7 |
![]() | and another ........... |
| | #8 |
| Registered User ![]() Join Date: Mar 2003 Location: Pleasanton CA Age: 30 Bike: 02 fiddy(88cc) , 2002 954 Gender:
![]() | Thats a real sweet mod, I went and dropped the coin on the over priced one from fast 50s it works good and locks the back tire, But I'm working on putting a system on there that allows me to run both the foot brake and a rear brake on the handle bars. But I think I'm going to model it after the way they do rear brakes on a ATV quad with the double bracket on the rear and the two cables going to it. |
| Thread Tools | |
