Go Back   Stunt Bike Forum > Main Discussion Forums > General Sportbike Discussion
User Name
Password
Old 04-23-2007, 11:51 PM   #1
Zer0 Profile
Bike: '00 929 (only pieces left :( , '02 R1, '03 CBR600rr, '04 CBR600rr
Gender: Male
600rr parts swaping 929 ?
I know alot of people go after 929 forks to put on their F4i's, but I have an '04 600rr that I want to beat up, and was just wondering what kind of parts will be compatible, and what is a good idea.
-will 929 forks go on an '04 600rr (would you need new wheels?)
how bout the '05 600rr inverted forks (new wheels again??) is it worth it?
I was also thinking about putting the '05 front end on the '04 race bike I have, but I know '05 and '06 used a different frame, but not THAT different, I wonder if the new inverted forks and wheels would be ok to put on it, and if it would be that much more benificial. Any Ideas on part swapping between the '03/'04 600rr and anything else. '05/'06 600rrs/ 929/954/1000rr... i would be interested to hear about.
Zer0 Profile is offline   Reply With Quote
Sponsored Links
Old 04-23-2007, 11:57 PM   #2
AsphaltAssault
AsphaltAssault's Avatar
Bike: 01 f4i, 96 900rr, 04 crf50r
Gender: Male
Re: 600rr parts swaping 929 ?
yeah you want to use 05-06 600rr forks. its definitly worth it. if i were you i wouldnt use 929 forks theyre a little long for that bike.
AsphaltAssault is offline   Reply With Quote
Old 04-24-2007, 12:10 AM   #3
old man roger
Bike: OMR PREPPED 636
Gender: Male
just put a set of 06 rr forks and tripple on an 03 rr the wheel from th 03 worked rotors and all....
old man roger is offline   Reply With Quote
Old 04-24-2007, 12:13 AM   #4
old man roger
Gender: Male
we even used the fender off the 03 but we did have to make two straight brackets and drill four holes in the brackets
Old 04-24-2007, 12:41 AM   #5
Zer0 Profile
Gender: Male
really the wheels worked ?? I thought they changed the brakes and rotors or something ?? that would kick ass. you made a bracket just for the front fender ?
Old 04-24-2007, 12:51 AM   #6
old man roger
Gender: Male
the 05 06 has radial mount calipers but the rotors are exactly the same ...
and yea we made a bracket for the fender because it was all the bike needed to be 100% done so i just cut two peices of 1/4 by 1 inch steel and drilled 4 holes in each one two for the fender to bolt to and two to bolt to the forks ....it was a little over kill strenght wise but it's what i had here...
Old 04-24-2007, 10:33 PM   #7
JoeR1
JoeR1's Avatar
Bike: 02 R1
Gender: Male
Yes the 05-06 forks mount right up to the 03-04 , and wheels are the same...did this same swap last fall...but we just used the 05 fender...
JoeR1 is offline   Reply With Quote
Old 04-25-2007, 09:46 AM   #8
flavadavescbr
flavadavescbr's Avatar
Bike: 2003 600RR STREET,2004 600RR STUNTER, 2007 FIDDY
Gender: Male
yes it does work OLD MAN ROGER is talking about my bike i will post up a pick shortly
flavadavescbr is offline   Reply With Quote
Old 04-25-2007, 09:48 AM   #9
flavadavescbr
Gender: Male
as you can see from the pic 2004 600rr with 05-06 front end with 03-04 fender works great and looks great too.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
SEO by vBSEO 3.0.0 RC6
