Go Back   Stunt Bike Forum > Main Discussion Forums > General Sportbike Discussion
User Name
Password
Old 03-28-2003, 01:34 PM   #1
metal doc
metal doc's Avatar
Bike: 98 GIXXER 02 XR50R
Gender:
SRAD owners help me out
I have a 98 750 and just discovered that the plug that comes from the generator cover was melted . I bypassed the plug by hardwiring it.
I figure this might explain why my bike was acting up lately. Sometimes it would act like it had a dead battery. It would be totally random and drove me nuts.
So anyone else have this problem ?
Did it damage anything else in the electrical system ?
How do I test the rectifier to see if it is okay ?
Thanks guys for the help , mike
metal doc is offline   Reply With Quote
Sponsored Links
Old 03-30-2003, 09:26 PM   #2
cstmgsxr
Bike: 21" Mongoose???????
Gender: Male
you could try and locate a hobby shop that sells highly expensive radio controled cars, and they should have a surplus of plastic parts and you can fabricate your own out of those, they start big then you cut them to the correct size, especially all the different plugs they sell for radio controled airplanes, as far as wiring, a little heat shrink should fix you right up, and if it is a problem of it getting near a heat source for to long, ask the hobby guys for some, fiberglass shielding to protect it, as far as testing your rectifier, im not sure....
As a matter of fact im not sure if that will even help you at all, since you have bypassed the plug already, but you should make sure there was not a relay for that circut, that you could have surpassed.
cstmgsxr is offline   Reply With Quote
Old 03-31-2003, 12:08 AM   #3
standy
LAWN JOCKEY
standy's Avatar
Bike: '94 900RR/'01F4i
Gender: Male
This is a common problem on all newer bikes, especially 900RR's and GSX-R's. Get rid of the hardwiring...the coupler acts as sort of a safety valve....when the output is high, the wires get hot. When this happens, the connector melts, because that is the point of highest resistance. If you hardwire it, the stator becomes the highest point of resistance...this will overheat it, causing failure. Your solution is to visit your local Honda dealer and ask the parts guys for an A/C coupler repair kit...usually its sold to goldwing customers. Solder the new connectors to your existing wiring, and you'll be set. The kit comes with directions, the coupler, and heat shrink tube. Good luck!!!!
standy is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
SEO by vBSEO 3.0.0 RC6
